Drone637
Just thought I would throw together what we have hacking on in the shop the last few days.
The problem: The tires were rubbing the fender way to much once my springs broke themselves in a bit.
Original Solution: Actually put bump stops back on the SJ.
Solution we went with: Getting rid of a decent chunk of the fender. We wanted to keep a somewhat stock look with the full fender, so we went a slightly different route then most flat fender style conversions.
First, take on Suzuki SJ
Draw a line about where you want the new fender line to be.
Ignore that line and just cut wherever you think looks good.
Make sure that you don't hit any electrical on the inside of your fender.
Once you make your initial top cut, take out the sheet metal between the top and the bottom of the fender line.
Here we decided to keep the original headlights. Another method would be to head straight to the left and put in rectangle headlights. Late 90's Chevy full sized rigs would be just about perfect. So draw a line on where you want to make the next cut.
Sawzall!
Weld up the back side of the fender that you cut out.
Push the front of the fender together and weld it in place.
You should have a gap under your fender, use a piece of scrap metal to fill this up. We used left overs from the fender on one side. It worked, but was a pain to weld. On the other side we just used some 1/8th we had laying around the garage.
Next we built a guard for the headlight to replace the part we took out of the fender and welded it in.
Clean up your welds.
Throw some paint on it.
Put the lights back in and your done.
There are larger pictures online at http://picasaweb.google.com/Drone637/SJ410Fenders
I'll throw some pictures up after the test run on Saturday and see how it works.
Sawzall!
