Sold/Expired FS: 50" Wurton 10W LED light bar
Dookey
Posting my 10W Wurton light bar up for sale. This light bar maybe has 10 minutes of run time on it and is in perfect condition. Used for mock up and promotional use. Has never been off road. Should be considered in like new condition. I have all 3 protective covers that go with it as well as the mounting feet and hardware kit.
Specs:
Raw Lumens: 28,000
Amp Draw: 21.0
No. of LEDs: (28) 10w LEDs
Housing Length: 50.71"
Reflector Style: Combo (24 Center Spot & 4 Outer Flood)
Features:
Rated for 10-volt to 30-volt Operation
10-Watt CREE LED Bulb (1,000 Raw Lumens Per LED)
Combo 10-Degree Reflector (Spot) & 40-Degree Reflector (Flood)
IP68 Rated for Dust & Moisture Ingress Protection
16-inch Lead Wiring with Delphi Connector
50,000-Hour LED Bulb Life Expectancy
Operating Temperature of -40 Degrees F to +145 Degress F
Stainless Steel Hardware
Aluminum Side Cap
Polycarbonate Primary Lens
Integrated Polycarbonate Secondary Lens Cover
Aircraft Quality Aluminum Housing
Aluminum Mounting Bracket
Limited Lifetime Warranty
Link to product:
https://www.wurton.com/50_LED_Light_Bar_p/21503.htm
Pics:
With Amber cover
With clear cover
With black cover
With no cover
On the Jeep
Located in Wichita, KS at 67210 should you want to stop by and pick it up. This is a great buy on a fantastic light. Retail is $1784.95. You will find them listed around the interwebs at $1600+. I'm asking $1400 shipped. I am available almost any time should you want to stop by and pick it up.
Please feel free to call me at the shop at 316.337.5311 or email me at [email protected] should you have any questions.
Thanks,
Andy
