TOYTOACRAWLERS
- Joined
- Nov 4, 2009
- Messages
- 518
got alot so here it is
chevy dana 60 long inner shaft non neck down 75
chevy 60 short inner non neck down 75
chevy dana 60 short yukon inner 4340 new 160
2 new bilstien 5125 12 inch travel shocks 100
4 15x8 trailready hd alum beadlocks 6 lug ben to woods 4 times 1000
top shift yota case 100
ifs yota rearaxle 410 gear open backin plates removed 125
yota knuckle gusset kit in plastic 40
yota front axle top gusset diff gaurd 410 gear welded 275
yota front axle 430 gear 175
350 turbo 4x4 builder trans 125
dana 60 front ford high pinion solid diff cover yukon inners and outter super joints new spool knuckles been rebuilt and wheel bearings are fresh drive flanges high steer 3/4 ton brakes 2700 obo
wilwood type brake pedal reverse mount dual master cyl new in box 125
2 sets taylor plug wires new in box ls1 50 a set
jegs trans or oil cooler with fan 125 new took out of box sold
flexlite trans cooler part nunber 45265 never had fluid in it 160
steering cooler frame mount type #6 fittins sold!
derale fluid cooler stacked plate part number 51606 $60
carbon fiber trans temp new box is tore open 75
used silver face autometer volt gauge 10
used autometer silver face oil psi electric 35
coil covers for ls1 polished alum new 175
ls1 truck intake fuel rails and throttle body cable drive 125 for all
polished alum fabricated valve covers ls1 new in box 125
dana 60 polished alum finned diff covers got 2 new in box 85 each
toyota lockin hub outter caps got several 20 each
97 model vortech 350 484 lift hyd roller camshaft edlebrock intake polished alum valve covers runs great hold good oil psi 1500
4 chevy dana 60 knuckles 2 lefts and 2 rights 125 each
will add more later call or text 423 421 9399 thanks
i got some more knuckles with high steararms for and dana 70 axles for you , see ya this weekend. dont forget my driveshaft .
