Metalbender
-=WTF=-
Specifications 37
I like the options below the 184:1 90 70 50 35 all good trail running gears but the 187 just seems Impractical
swap in a 4:1 trans instead. thatd give u 120:1I like the options below the 184:1 90 70 50 35 all good trail running gears but the 187 just seems Impractical
What does the doubler half to do with belly clearance? With the d.d adaptor you can rotate the 3 300 flat and the 241 range box is not any thicker than the d300 tcase?
thats yota territory, it should be fine.We are going to stretch the wheel base to like 104 so it should be ok? What is you wheel base?
I agree drive train placement means more than wheel base, but it helps keep drive angles flat. any one else running a round 175 to 1 low range?????????
I think my Bronco is around 134:1 with an Automatic and i love it
im FINALLY at like 65:1(130:1), with my auto...it could be lower.brandon, with an auto that is like 260:1 with a stick, that is deeeeeeeeeeeeeeeeeeeep
