Gearing front to back????
xjpaddler
Looking at a couple things for my next build, i am wanting to run 4.56 gears. 14 rear, portal hybrid 9 in the front.
What is the most acceptable gearing difference from front to rear??
For instance
4.73 front 4.56 rear?
I will have to regear the front 9 but not sure how close i can get to a 4.56 total
I'd rather have the faster gears in the front if that's a choice (if you can get close enough).
5.38/5.43 is a common hp44/9" combo
I've seen 5.86/5.71 in a lp44/Toyota axle combo...
Agree completely on the front being faster!
The big question is are the portals 1.1 ratio or 2.1 or something else?
Hummers, portals and 1.92-1 is what i have found. I can get the front to 4.66 and the rear at 4.56. Any thoughts??
Nick do you have a source on the 1.72 everything i have read said 1.9
Still cant believe im thinking of going this route. Ive wanted to do an IFS set up for a while. The portals kinda fell in my lap over the weekend, and aparently are pretty strong. The rig will be rear engine with a flipped 14-rock hybrid rear. If i have done my math correctly, i can run 2 in spacers on the rear and be at 67.5 wms. Running 2stubs, and long side+stub. Should put me around 82 width with center line wheels.
xjpaddler said:
I already have 4.56, for the 14b What i really need is 2.64s for the 9in;)
Nope, I just did 4.56/2.64 that you posted earlier and came up with 1.727...
I guessed hummer portals.
