GM zz crate motor 355hp -1800.00-----bought it from a friend of mine that used it once for a chassis breakin on race car--2yrs ago--run it two season in a wrangler--jus pulled it --motor is strong--age maybe 4yrs--miles not many maybe 1-2k
TH350--jus pulled it works great--fresh rebuild may have 1000miles--with convert.--400.00
2" 7075 alum link bars two bars are 39" and two are 34"--4 bars tapped and threaded for heims --550.00
16 QA1 heims 1.25 with 1" hole 8 new 8 used---500.00
4 swayaway 16" 2.0 series coilevers new never mounted--with new black shafts --comes with dual rate kits SOLD
Ford HP60 front drivers drop-trussed-no tabs--blasted have 5:13 gear(new in box) to go with --complete less calipers -1700.00
14bolt rear all stripped ready for the truss--have ARTEC wide profile truss and pinion guard not mounted brand new --discs brakes 5:13 welded--900.00 for all
Crane high steer arms and arp stud kits--brand new--400.00
custom axle outer link brackets--150.00 for both sides
custom chassis outer face side of link mount bracket--100.00 for both sides
32 ss mis alignmnet spacers---100.00
16 QA1 weld in bungs 1.5od for 1.75 tube-- 240.00
trnsfer case weld in mount bracket---50.00
