Sold/Expired Heavily Built Crawler on 37" Red Labels (Streetable w/ tire change)
Allgood_73
Nashville, TN
Located in Nashville, TN - Willing to ship (~$725 anywhere in the country) or meet within a 300 mile distance (you pay for gas).
$13,500 - Jeep with NO wheels or tires
$14,500 - Jeep with nice 35" tires and nice black steel wheels (streetable)
$15,500 - Jeep with 37" BFG Red Label Krawlers and Walker Evans beadlocks (non-streetable)
It's a 1993 YJ 2 seat crawler, done well. No expense spared. Well maintained.
The details:
-Rear Axle is Currie Rockjock 60 (~ $5,000) with ARB air locker, 5.13 gears and Wilwood 12½" Big Disc Brake Kit, Warn hubs and Chromoly shafts.This is the one with the canted ring gear (leaned forward for ground clearance - see 3rd picture below)
-Front Axle is Currie Rockjock 44 (Receipts for $2,700) with ARB air locker and 5.13 gears.
-CTM U-joints, chromoly shafts, Warn hubs and differential skid.
-Both axles are strap limited.
-New 231 transfer case with Teralow 4:1. (Receipts for $1,700)
-Rock Krawler X-factor 7.5 lift and suspension with RRD Racing front coilovers, stretched and coils in the rear (Receipts for $7,047 installed). The flex on this system is unbelievable with the 3-link in the front and 4-link in the back.
-New rear Skyjacker soft ride shocks
-BFG Red Label Krawlers 37x12.50R17 tires with Walker Evans beadlockers ($2,500+) and rock rings. If you've never wheeled them or wheeled with someone with the red labels then you really don't know. Unbelievably sticky. Tires and wheels show considerable use absolutely no leaks or issues. Also have a spare with perfect wheel. These tires are NOT DOT legal. You are not supposed to drive on the road with them. You can, and I do, but I don't want there to be any misunderstanding. You are not supposed to drive on the highway with them.
-Two sets of onboard air (ARB and Kilby with air tank) - chucks at front and rear. The Kilby really pumps out air up to 150psi into the on board tank and there is a regulator for the lines that go to the lockers. Pretty slick.
-Air conditioner compressor still present and functional.
-PSC Hydro Assist Steer.
-Big steering components.
-Steering box brace.
-Aluminum 15 gallon Fuel Cell behind the B pillar.
-Full Custom Cage tied to the frame but still removable.
-Genright and Custom Armor all the way around and underneath.
-Tube fenders and Comp cut corners.
-Nice Stinger Winch Bumper. Stinger and bumper are removable.
-Warn 9.5ti winch with dash control.
-Mastercraft Rubicon seats with 3 point harnesses.
-Inside and dash are in great shape.
-Interior is sprayed gray bedliner.
-Cobra hand held CB 75 WX ST with an extra speaker mounted high on the dash.
-Full soft top (Bestop).
-Bikini top.
-Hard half doors.
-Brand new (from Autozone - I can provide receipt for future use) Optima Battery.
-Hidden Kill Switch.
-Locking Hood.
-Cold air intake.
-AM/FM CD MP3 USB stereo with 6x9s and dash speakers.
-Rock Lights (Cheapies for now).
-LED tail lights.
-Strong 4.0L with around 125k mi. I have every receipt from oil changes every -3,000 miles since new.
-Recently rebuilt Torqueflight 999: The A999 (later renamed 32RH) is a heavier-duty, wide-ratio version of the small-frame A904 transmission for use with medium-power V8 engines. It has lower first and second gear ratios to allow the lower-powered engines to provide better acceleration without sacrificing highway fuel economy. – 3 speeds - Auto transmission.
-Transmission cooler.
-Street legal, drives perfect. No wobble, no pull, no issues. I rarely drive on the road though for two reasons; no swaybars and tires are super soft and sticky.
-New (used) tub was replaced and custom painted not long ago, looks sharp.
-Fairly new exhaust.
-Everything is very clean.
-Very little body damage or even scratches considering all the stories this rig could tell.
-Everything works (heat, wipers, lights, etc. etc.)
Clean / Clear title.
Licensed, passes emissions.
-Never driven hard or ragged on. Nice and easy.
Known issues:
-Upper spring on both coilovers are sagging these days. Driver's is slightly worse so it has a slight lean.
-Small pinch in rear driver's brake line. Very accessible. I tried a bunch of times to replace it, but I couldn't flare the brake fittings well enough. It still passes fluid, but probably reduced flow.
-Passenger seat has a small rip (grrrrr)
Crawler Rockcrawler Rock Jock Dana Jeep Wrangler TJ YJ CJ Built Locked Clean Streetable Buggy Moon Bead Locks Beadlocks WTT WTS Sell Trade GA TN KY AL FL Georgia Tennessee Kentucky Alabama Florida link linked steal Excellent Nice deal
I've got a few offers on the red label tires / wheels.... I might be willing to sell separate for the right offer..... otherwise, I'll just wait until after the jeep is sold to see what "price option" was picked.
Sale fell through, so I'll be parting it out and listing things up.
PM me pics and more info of your LJ.... might be interested.
