fairly certain it won't be able to time itself. part of what the tbi system does, is adjust timing as needed when it senses knock/etc. Not saying someone couldn't make it work, just stating that it is made to be in there
[/quote
Your right on Kelly... I run a fast kit TBI with an HEI distributor and the kit came with a small module to "clean up" the dirty trigger signal from the HEI...From what I have heard, he will have to trace the wire on the main wiring harness that gathers the trigger signal off of the distributer and rewire for the HEI with a wired in filter...Call the guys at FAST they should be able to tell you for sure... Here is there website info
http://www.fuelairspark.com/ Good luck RBaker
