grcthird
Birmingham, AL
Doing a rear disc setup using the Chevy calipers, I need to find some adapters that will screw into the calipers and also fit the metric brake lines. Or some brake lines with chevy on one end and toy on the other. Thanks.
TBItoy said:On all the ones I've put together, I used the factory chevy soft lines, then put the correct standard male fitting on the hardline on the axle.
That way you don't have any "custom" parts
smbroady82 said:a little off topic...but, what kits are all you Toyota guys buying/running for your disk brake swap??
