Hey. It's me. I gotta question need answer ASAP. Thanks
Casey
So finishing up the Motor. I have to ask. What's everyone doing as far as a single ended ram on LS Pump? Will my can with reservoir attachment from PSC for my 400 sbc fit the pump for LS ? Or do I use stock resivior. Thanks! Helpppp!
Should fit with little to no modification assuming you have the LS truck accessory bracket. You'll need a LS serpentine pulley to put on it.
slytowncrawler2 said:
No need for reservoir. My stock pump an reservoir with a big cooler feeds my front and rear..... **** u not.
Are yours single ended Rams or doubles? Fluid level changes a lot mor on the singles.
Mines a single....8x2.
I wanna say it's got like a 10" section of hydraulic hose clamped to the OE reservoir and then the OE screw on cap is hose clamped on top. Small hole drilled in cap for vent.
Re: Hey. It's me. I gotta question need answer ASAP. Thanks
Ghetto...
Both mine are 10" tractor supply singles, Eddie..... But yea I doubt I could get by if I had double ended Rams. Mine is right at the limit. With both cylinders extended it damn near empties reservoir .
