blacksheep10
XBJRA champ/ 555 and team Nasty codriver
If you drop $800plus on an old ford 60, you then have to buy knuckles because they're weak. Then you're stuck with 3 year old castings and 3.125" tubes. This way you put all HD **** on it and rock out for near the same money, and be way stronger!
$300
4.10 ratio open carrier
3.5" tubes
inner and outer axles with stock joints still there.
High pinion, gears still in there and set up, yoke still on it. I took the unit bearing outers off it, you can have a big tube, better casting center and glue Solid C's and outers on it to be rock ready, or spider c's, whichever
Yes, it is a 60 center section, not a 50, the pics tell all there.
Kelly
913.731.3040
Paola, KS 66071
$300
3.5" tubes
Kelly
913.731.3040
Paola, KS 66071
