How much coolant for rear rad?
Trailpunisher
Active Member
Running Evans waterless coolant and just need to know how much to buy. Rear radiator all 1.75" lines and a small block Chevy . The radiator is a 16x31 with twin 1" cores. Thanks
believe mine was about 6 gallons also. I left radiator hose off at thermostat housing till water came out to make sure all the air got out.
I'd order 7 since you can't mix any water in. I've been reading on this for a few days now. You never know if you may have to top off.
Not familiar with that coolant but if it won't mix with water I would consider other options. It's not uncommon for a rear radiator rig to have air in the system that may not show up rite away. In fact I rolled my buggy this last weekend, and after a full day of wheeling the following morning started running hot...This happens to a lot of people. Water is everywhere!
I just looked this stuff up holy **** that's expensive is it really worth that kind of dough
Yes it is because it won't boil over like water that way with he radiator right behind me I won't get burnt.
