The problem is that it won't turn right. it used to work i drove it around the block once and put it on a trailer. Then when i took it off the trailer it didnt work anymore. it is a trail gear orbital with a agurcultural ram with a clevis on the end of it that is mounted underneith the tie rod. i mounted my orbital on my buddys truck and it worked both ways. and his ram has much more of an angle and it works and my angles are pretty damn good but i still have no right. and if the tires are off the ground it works both ways.
