and a tip if you ever replace the trunion bearings and races.. freeze the races and right before you take them out of the freezer heat up the spot where the races will be going with a propane torch .. they glide in with a little hammer work :redneck: . im sure everyone knows this but hey im 17 and learnin so i thought i would share
Thats pretty common knowledge for just about anything thats a press fit. Although, the trunion bearings are pretty easy to install IMO. Just set them in place, and tap em in with a brass hammer. They don't sit below the surface of the knuckle ball, so its really easy to get them seated this way. Wheel bearings I could understand trying a way to make them easy since you cant just tap them all the way into place with a hammer because they sit down inside the hub.
Anyway, looks like youre doing a good job! I just got some more of my front end done tonight too. Got the diff in, axles in, spindles on, hubs, rotors, calipers, brake lines, etc. Still gotta put the locking hubs on (need to get new nuts and washers), hook up the front driveline, fill the diff, bleed brakes, and finish the crossover install.
Feels good to be so close. Too bad I just found out the wheels wont fit with the new large piston calipers and vented rotors
I knew there was a possibility they wouldn't fit, but I was hoping they still would.
~T.J.
