skipnrocks
SbC 350 with the distributor that has the plug for the coil and another plug that goes to the engine harness.
Here's my question. I know that to set the initial timing on the old vacuum advance distributors you would disconnect the vacuum and start it the rotate the distributor until it sounds best. Then hook the vacuum back up. With mine being fuel injected and having the computer playing with timing should I disconnect the computer from the cap then do the initial timing to ear. And then hook it back up. I am running first fuel injections tuned port injection kit if that helps.
