installing mechanical water temp gauge on a yota
skinny_pedal
Enumclaw
im installing a water temp gauge. the two sending units on the intake are brown and green. the mechanical unit won't fit in the green hole, so i hope using the brown one is correct? this is on a 22re.
The brown one controls your cold start injector :D
--toyguy--- said:
drivers side under the header above the oil pan, there is a coolant drain. thats what i used.
what gauge did you go with? i just bought a cheap sun-pro and it doenst have a fitting to fit in the side of the block
