Listing for a friend:
$11,000 OBO
$11,000 OBO
Engine:
350 4 bolt main
Bored 30 over stock
Crank shaft turned .010
Stock heads (valve job)
Aftermarket valve springs
GM heavy wall pushrods
1.5 ratio GM self-align rocker arms
Clevite bearings
Fel-pro gaskets
Crane energizer camshaft .480 lift .280 duration
GM double roller timing chain set
GM harmonic balancer
Gm flywheel
Advanced adapter block hugger headers
Holley truck avenger 670cfm carb
K & N air filter
MSD off-road ignition box
MSD blaster 3 ingnition coil
MSD pro-billet distributer
MSD 8mm plug wires
Weiand high flow water pump
150 amp power master alternator
Yellow optima battery
Holley red electric fuel pump
12 gal summit fuel tank
Transmission:
Turbo 400
Kolene clutches
Keviar bands
Brass bushing
Reworked valve body ( shift kit installed)
Extra deep finned aluminum pan
B & M transmission cooler wit electric fan
B & M mega shifter
Transfer Case
Atlas II 5.0
32 spline front an rear output shafts
Drive flanges by High Angle Driveline
All aluminum gear drive
Twin stick shifter
Drive Shafts
Front shaft
Long travel slip yoke with boot
1410 u joint at diff
1 ton rated toyota yoke at transfer case
Heavy wall tubing
Rear shaft
1350 C.V. joint at transfer case
1410 U joint at diff
Heavy wall tubing
Front Axle
GM style dana 60
35 spline axles
1410 yoke
Mile marker lockout hubs
ARB airlocker with ARB compressor
4.56 gear ratio
Blue torch diff cover
Rear Axle
14 bolt axle
Detroit locker
4.56 gear ratio
1410 yoke by High Angle Driveline
Gauges
Auto meter phantom ( white face)
5 inch monster tack wit shift light
Speedometer
Water temp
Oil pressure
Trans Temp
Volts
Fuel
Air pressure
Lift Kit
Pro Comp explorer 4 inch
Pro comp es3000 shocks
Tires an wheels
39.5 x 18.50 x 16.5 interco boggers
Trail ready beadlocks 12 x 16.5 black wheel wit yellow lock rings
Steering System
AGR Rock ram
Hydarulic Assist
AGR super pump
Interior
Mastercraft suspenion seats
5 point master craft harnesses
Grant steering wheel
Full roll cage (6 point) by poison syder
Wheel base 114
