Sold/Expired Kilby onboard air setup for 4.0 TJ Wrangler
creepycrawly
I have a kilby onboard air setup for a 2000-2006 wrangler with a 4.0. This uses a York compressor and moves the alternator.
Use this to air up tires or run air tools on the trail. Comes with the kilby bracket which can't be purchased anymore. Also comes with the York compressor, the needed hardware, and the lines.
I have a coalescing filter that will come with it, but the site glass on it is cracked. This was used to run my arb lockers. Also will include a viar 2.5 gallon tank. Kit was over $1000 new.
Located in Milton, Florida. $600.
$500 for the whole shooting match. Run arbs, air up tires, run an impact on the trail.
jeeptj99 said:
To bad it doesn't work on a 99. Wonder what changed between years??
They did away with the distributor. The pump sits where the distributor is on yours.
Well that sucks. I have needed air several times and not had it. been through several harbor freight compressors this would have been sweet.
I have an additional pump that I'll send with it for $50 extra. $550 total with 2 pumps.
