Lab Rat (TurboTruggy)
  • Thread starter Thread starter doctorhomo
  • Start date Start date
Status
Not open for further replies.
D
doctorhomo
Guest
Lab Rat (TurboBuggy)
Well, for a long time I've wheeled a streetable rig and have finally beat it to a crumpled mess.
Jeepers Loooooooove those winches. I had to snap this shot of these two Winching at the same time.:fawkdancesmiley:
So into the lab it goes: Looks like you need a bad operation.
CHOP !!!
I rebuilt this 22ret a short while back. It has forged pistons and eagle rods LC engineering crank. Home job ported and polished gasket matched. No cat or muff, just 2 3/4' pipe. It has about 1,000 miles on it.
It throws the turd around pretty good, but I have a Gen3 Supra that I'd like to put a 2jz in.
The engine has 102,000 on it and I replaced the head gasket at 80,000
As soon as I find a junkyard bellhousing The 7M (turbo OR n/A) bolts to a W56(my trans) using a 5M or 7MGE (n/a) bellhousing.
Until then the current powerplant will suffice.
I'm starting with the rear axle since I'll be linking it. First I cleaned off all existing brack brackets and bent a 2"x .250 wall for the top.
Quick mock-up
Now, I've seen alot of people running store bought diff covers and frankly, I think they're lame. I gathered same scrap and went to cutting and fitting
Simple cardboard patterns
Scribed shape with sharp tungsten
Guide set out for torch
Tacked in place
Finished
Now that you've got that cover all made up & on the housing(looks good BTW), how you gonna check the diff oil???:eeek:
How do you plan on filling and checking the gear oil? dipstick?
**** it. it looks good bro :awesomework:
I've got an old 22r dipstick I cut down for the breather hole. I drilled and tapped the hole to 1/2 inch so I can fill it easier.:awesomework:
It's looking good, can't wait to see when it's all said and done.:awesomework:
Layed some hammered owl **** on for strength.
Now I'll cut my tacks to the housing and lay some **** on the inside. Once that's done I'll cut some prissy little triangles to finish the install.
WoW !!!
This sure is a switch from all the booger welders who have build threads on here.:redneck:
Keep it coming:awesomework:
I sure hope this does not take as long as your brothers pile of **** :haha:
I would have hoped to see better welds coming from you :looser:
Your a *** wheres your rig hidden under a pile of gay **** or are you still trying to figure out how to make the dildo you mounted in your seat go up and down.:fawkdancesmiley: :fawkdancesmiley:
**** you I know who you are now :fawkdancesmiley:
At least I build my rig and not be some one elses ***** and build theirs for them :flipoff:
I need my front third ***** :awesomework:
you mean try to build your rig , and you will get your third as soon I see you again. Took you long enough to figure out who I am Hom:flipoff: o
Status
