tennessee_4x4_man
- Joined
- May 19, 2013
- Messages
- 547
ok guys pulled factory tank from my 93 yj going to buy a fuel cell which pump do i need i wount to have a external pump on my frame have you guys got any sujection its a 4.0 motor
hokie_yj said:I put a walbro 255 on my YJ buggy with a 4.0. When I bought it it had a knockoff e2000 on it and it wasn't cutting it. It crapped out at High RPM's. That e8248 will work too, I believe it's basically the same pump.
scrambled said:Thats interesting to hear as I have a YJ buggy that will do the same thing. Does it make the motor stumble like its running out of fuel?
Isn't the Walbro an in tank pump though?
Here's pictures of my setup. I did something similar to what it sounds like you're going to be doing.tennessee_4x4_man said:i ordered one from summit got a fuel cell on its way was going to mount the cell in back of the jeep and mount pump with tank and filter had in mind to mount it all beside tank that way it all be in the dry any sugestion on where pump and filer to to be mouted to work the best the fuel cell had the 3 -8 fiting on top whick i ordered 3/8 to got to the -8 fitings
tennessee_4x4_man said:so i ned to cut a hole in the cell and make it botom feed **** i was hopeing it would pick it up from the -8 line on the top
I did it with wing nut hose clamps so I could change it out on the trail if I need to.tennessee_4x4_man said:yep i had in mind to do just like you did man that looks killer
