Will a chevy 5.3/6.0 harness fit an Ls1 motor.... Also can the 5.3/6.0 ECU be tuned to run the LS1. I had a 6.0... It blew so I swapped motors and had ECU retuned for the current 5.3 I'm running so I know these two will swap but unsure of the LS1
gdf said:Will a chevy 5.3/6.0 harness fit an Ls1 motor.... Also can the 5.3/6.0 ECU be tuned to run the LS1. I had a 6.0... It blew so I swapped motors and had ECU retuned for the current 5.3 I'm running so I know these two will swap but unsure of the LS1
they are you just have to repin harness lots of info onlinepholmann said:They use the same exact PCM for v6's also. They just have to be set and tuned for whatever you are using. I think the biggest thing is DBW and DBC. They aren't interchangeable I don't believe.
