roll over dave
Is there anyway u can clean clogged injectors ive heard u can boil them has anybody heard of that and ideas please post up
Travis said:Soak them overnight in seafoam. The test them with 12 volts. I cleaned plenty of clogged injectors this way, worked everytime.
I take 12 volt straight from a battery, positive to one injector pin, negative to other injector pin. It'll click if its good, fairly loud. You should be able to tell a difference in sound between good injectors and clogged/dirty ones. Any that sound quieter, soak overnight again.wizzo said:how are you testing them after they are cleaned? just wondering what the process is.
