Sold/Expired LS motor moving sale. 5.3 LM7 ,stock LQ4 6.0 Vortec 4L80 Auburn, AL
95limitedzj
Auburn, AL
http://auburn.craigslist.org/pts/5303131217.html
relocating soon and would rather sell these projects than move them.
I have a 2004 150kish mile 6.0 LQ4 $1500
-317 heads
-drive by cable throttle body
-complete intake to oil pan including exhaust manifolds, exhaust cut after O2 sensors, included.
-includes all accesories, stock harness, stock ecu
- I can unlock the computer for you, for your swap for another $100
4L80E trans from same van : $700
- Used in working condition with Torque Converter
- can include original aluminum driveshaft if needed
5.3 LM7, recently freshened and prepped for Boost application : $1800
-Can hear run on engine stand!!
-professionally reworked stock harness with fuse/relay block and 2 wire easy hookup (easily $500 alone)
- unlocked and base tuned ECU included
-97-98 LS1 cam (probably 30hp upgrade over stock truck cam) (boost friendly)can include stock cam if you want it.
-new pac 1218 valve springs ($150 new)
-new pro-comp head studs (needed for boost applications)($100 new)
-new valve seals, spark plugs, MLS Head gaskets (~$100 all new)
-heads cleaned and valves lapped
-includes truck intake and Fbody Oil pan/pickup/windage tray. (can swap to truck pan for $150 less)
- brand new starter, all other accessories included. Has dirty dingo idle relocator to run car intake with truck accessories. Stock truck manifolds cleaned and painted with high temp paint.
- drive by cable throttle body
- oil pressure gauge can be included
txt or call with questions 2O5-4IO-3I28. These are cash prices and can be flexible, so bring cash and we can talk. Will not negotiate for days over txt/phone and then again in person. If you want parts off either motor we can probably work something out also.
Engines are both on 1000 lb engine stands which can be included with either engine for an extra $75.
hokie_yj said:
Damn I need that 5.3 for my next project. Why do I have to be broke right now? :'(
Work something out with him Ben. I'll hold onto the motor until you can get it.
6.0 is sold.
5.3 and Trans are stilll available.
Pulled tailhousing on the 80e and it had the fully splined output shaft that van be cut down for use in 4x4 applications with stock tcase adapters.
I don't check this very often so shoot me a txt or call me if you need something. 2054103128.
