The Warn factory is just down in Portland. The techs are cool dudes, who fixed my 12000 for free. Since I was already heading down there anyway, it was very convienent also.
If you get in over your head, let the Pros fix it.
However it's been my experience the the number 1 failure of most winches is either the power and ground cables are undersized, corroded, or ground to the frame instead of the battery, -or- the one of the solinoids died.
regarding your fairlead question, you typed "winch line", without clarifying if the winch line in question was 'steel' line or 'poly' line. If it's steel line, then as long as the gap in the rollers is larger than the diameter of the line, your OK, just feed the line thru the fairlead, and spool it onto the winch. IF the line is poly, then you should get a HAWSE style fairlead, designed specifically for a poly rope.
