My question is regarding the use and differences between GL4 and GL5 rated manual transmission lubricants. From everything I find searching, it sounds as though GL5 is not good to use in transmissions with yellow parts, ie. brass synchros. But looking in the manual and online, the samurai transmission calls for API GL-5 75w90 GM Lubricant. :eeek: I was running cheapy gl5 80w90 in it after rebuilding it, and it still had a whine and notchy shifts. I swapped in some Lucas synthetic 75w90 trans and diff lube, cause I couldn't find anything with a GL4 rating. The whine is mostly gone, and the shifts are alot smoother. I'm just wondering what I should be running in it, and what everyone else is running in their manual transmissions?
