John Galbreath Jr.
38 Special & Solo Buggy
- Joined
- May 24, 2007
- Messages
- 8,613
I have a milling machine I don't use and need the space for TorchMate 2x2 that will be here in about 2 weeks.
This universal heavy duty milling/drilling machine is constructed from rigid cast iron and steel to ensure maximum precision.
Easy to operate, the downfeed has both rapid and fine controls and a front-mounted depth gauge
Broad dovetails
Heavy duty gib
Large micrometer dials on table control wheels
Worm-feed gear
Head swivels 360°
Accessories include an adjustable carbide-tipped face mill, and a 1/2" precision drill chuck with key and arbor
Drill capacity: 1-1/4"; Face mill capacity: 3"; End mill capacity: 3/4"; Swing: 15-7/8"; Spindle stroke: 5"; Column diameter: 4-1/2"; Spindle speeds (RPM): 120-200-250-290-400-465-820-1090-1245-1520-1820-2500; Spindle taper: R8; Longitudinal table travel: 19-3/4"; Cross table travel: 7-3/8"; Table: 8-1/4" x 28-3/4";Motor: 1-1/2 HP, 110 volt, single phase; Angle vise capacity: 3-1/2"; Height: 43-1/2"
Shipping weight: 706 lbs.
This machine has seen very little use. Did one small milling job. Rest of the time used as a drill press.
Mine has a stand if needed, add $100, or I will use it for the TorchMmate.
Here are the actual pictures.
[attachment deleted by admin]
Broad dovetails
Heavy duty gib
Worm-feed gear
Head swivels 360°
