cutngut
Owensboro KY - Nick
Should i install misalignment bushings where the heim connects to high steer arm?
krackem said:??? Same as a lock washer
TBItoy said:Not at all, it's like a wide thinner misalignment spacer
crawlin85cj said:Save yourself some heartache and tig weld these to the steering arm or wherever you use them.
crawlin85cj said:I do it for a few reasons...
Can't separate and wobble if it were to loosen up.
The mounting hole depth is increased and strength is increased.
It can't fall off and run away in the dirt or garage floor.
It looks cool.
Same reasons safety washers are welded to link tabs.
cutngut said:Will i use these on top and bottom of the heim?
TBItoy said:If you need to for misalignment, you don't have to though. You could use just one on the "open" side.
Hell, you don't "have" to use them at all.
You can just use a regular washer, or no washers at all.
