Sold/Expired Motobilt Coilover Mounting tabs
motobilt
"I Build Stuff"
1
Dothan, AL
http://www.motobilt.com/catalogsearch/result/index/?cat=6&q=coilover&x=0&y=0
Dana 60
http://www.motobilt.com/coilover-tab-dana-60-front-kingpin.html
Mounting coilover shocks to a Dana 60 front kingpin style axle has a couple challenges and the Motobilt MB2006 tab answers them. The tab is contoured on the bottom edge (weld surface) to follow the axle tube and contour of the Dana 60 kingpin inner C. The tab is CAD designed from paper templates I have used many times over the years to hand fabricate a similar part. The part is CNC cut from 1/4" high strength steel plate and has a 1/2" mounting hole for the shock.
It should be noted this tab can be used to mount coilovers and standard gas shocks. The tab raises the mounting location vertical on the axle to help the coils clear high steer arms on the king pin style Dana 60 front axle.
Sold individually. You will need 4 of these tabs to complete the job. Contact us if you have any questions about your project and the parts needed.
FEATURES
1/2" Shock mounting hole is 4.25" from the base
CNC Laser cut from 1/4" high strength steel plate
Raises coilover up to clear high steer arms
Dana 44
http://www.motobilt.com/dana-44-inner-c-coilover-tab.html
Mounting a coilover to a Dana 44 front axle is made easy with these tabs. The tabs are designed to weld to the axle tube and inner c providing two purposes. Gusset the inner C and provide an elevated mounting point for the coilover. The coilover shock mounting point is elevated so the shock will clear the upper ball joint nut when the axle is articulated. The bolt hole is 1/2" to fit most coilover shocks and standard shocks. The tabs are CNC cut from 1/4" high strength steel plate. The mounts are sold individually.
Flat Mount
http://www.motobilt.com/flat-mounting-coilover-tab.html
The Motobilt Flat Mounting Coilover Tab can be used in a number of applications. The tab is CNC laser cut from 1/4" high strength steel plate. The tab measures 3-1/4" wide at the flat bottom base; The 1/2" hole is 1-1/2" up from the flat bottom base
The tab is meant to mount parallel to the axle tube to reduce binding at the coilover mounting point.
FEATURES
CNC laser cut from 1/4" steel plate
1/2" shock mounting hole
3-1/4" wide at the base
1-1/2" tall to center of mounting hole
can be used for standard shocks and coilover shocks
Coilover Shock Tab for 1-3/4" Tube
http://www.motobilt.com/coilover-shock-tab-for-1-75-tube.html
The Coilover shock tab for 1-3/4" round tube is cnc laser cut from 1/4" high strength steel plate. The bolt hole is 1/2" diameter to fit the standard coilover shock bolt size. The area around the bolt hole has clearance to allow room for the shock body not to contact the tab. The tab can be installed on 1-3/4" round tube and has to be welded in place by a qualified welder.
FEATURES
CNC Laser Cut from 1/4" Steel Plate
1/2" Bolt Hole
1-1/4" from center of bolt hole to edge of the 1-3/4" radius mounting surface
Designed for mounting coilover shocks
