Sold/Expired Motobilt Welding Square
motobilt
"I Build Stuff"
Dothan, AL
https://www.motobilt.com/motobilt-welding-square.html Motobilt Welding Square
The Motobilt Welding Square is CNC Laser cut out of 3/16" high strength steel. It measures 12" x 12" x 17" and is 4" wide. Holes are 1/2" and hole spacing is 2" on center. Slots are 1/2" as well. Could be bolted down sideways to a table, used as a fixture on a welding table, laid down flat and used as a 4" tall block and has unlimited other uses. Ships bare metal and in five pieces. DIY kit must be tacked together.
motobilt said:
No we do not.
I build a lot of square tube machine frames and tables (mitered corners) and use a regular framing square with some long #10 bolts tapped through it to elevate it off the welding table and hit the center of the tube.
The 4" width seems "bulky" to me. I might order one anyway...
