kushKrawlin
Well, just like ***le says.. She be shakin. Thought it was drive shaft or tires when I was going down the road. But I can get the shaking if I recall it up... Wat in the world?
JohnG said:Need to lubricate the reefer bearings.![]()
Where are they located? Thanks for the advice..JohnG said:Need to lubricate the reefer bearings.![]()
onepieceatatime said:I heard 5.3 motors run pretty smooth???
This is correct .. Thanks Ben. I'm gonna swap them wires out for new ones, and check all the bolts now.bbone said:Besides adjusting the timing, SteveO also repaired no less than 2 bad plug wires AND capped open ports on your mixer
