Take it to the Dealer !!!!
Or check a few things out.
How much fuel is in the sight glass?
Have you checked for large vacuum leaks? (this is kinda my guess)
Have you checked to make SURE you have the vacuum lines hooked up RIGHT?
Have you cheked to see if any fuel is squirting out of the main jet while it is running for that 30 seconds?
Does it squirt any fuel when you reach down and manually open the throttle? (do this when the engine is turned off)
These are good carburators that can go 400,000 miles easy. But have a couple simple problems that can come up.
The accelerator pump diaphram can die. It's an easy fix
The main vacuum inlet to the bottom plate can get all plugged up. (The vacuum line goes from the pvc on the valve cover to the center of the bottom plate, drivers side) Easy to check this by pulling it. The engine should instantly die from a HUGE vacuum leak.
That's where I'd start. If all this sounds like a foreign language, I will say again. Take it to the Dealer, or a trusted reputable mechanic who HAS A LOT OF EXPERIENCE WITH THIS VEHICLE.
Good luck :awesomework:
