under_psi
CROSS POST POLICE
OK guys...
i am mostly wiring weetoddid....and i need som eguidance b/c my main wiring guru is a car stereo and not a car electronic charging guy...he is basically helping me with the lights and relay stuff...
i need to figure out the main wire routing from battery to alternator to starter and the like...
what i am using is a 3 stage security feature for starting/non starting purposes (so it is a little more difficult to steal the car...) and then i have a main switch panel from 12volt guy that is a dual winch, IG toggle followed by a push start, then has the 8 fused switches for accessories...
before the IG toggle and push start, i am using a 'theft kit' from seabass as well...it is basically like a breaker master power key that is inline on the 4 guage to cut all power, and i also have a barrel key that i want to use as the 2nd keyed saftey...
so, i need to know how to run this power system....
i would like the main breaker key thingy to be the 1st saftey, since it is inline with some 4 guage, and then the barrel key, which will arm the dash panel from seabass, then the IN and push start...
really need help here....cuz i got dizzy last nite late in the evening trying to figure out how to wire it all from scratch.....
thanks!
thanks!
