smbroady82
Here is what I have going on
I bought the tg chromo solid axle hub replacements
https://www.trail-gear.com/TG/Solid_Axle_Hub__Creeper_Flange_Style/i_0_0_3543/_140435-1-KIT.aspx#.VOoxtuk5Bjo
Here is the difference in the new ones (right obviously) and what I assume are IFS style hubs that I guess I have been running the whole time ( had no idea the difference until now)
when I went to bolt everything back up the other day, there was not enough clearance to put the bolt thru the knuckle tabs & caliper hole and put a nut on it
here is the pass. side, you can see that there is enough room to run the bolt thru both and put the nut on
I just went to the parts store and bought what is supposed to be an 82 caliper and pads thinking maybe they would be tapped for the bolt..Wrong
So I get home and look at the caliper that I have been running for years and can't tell if they are any different at all.
So my question is: What am I doing wrong? Am I missing something? Wrong caliper or rotor?
This is a showstopper and I want to get it figured out today as I have to travel for work this week and will not have time to fool with it when I get back before the Gray Rock ride this weekend. Any help would be greatly appreciated.
I am close the truck and my lap top if anyone needs anymore pics to help
thanks guys
Broady
thanks guys
Broady
