So a co-worker has a KIA Sorento and it needed a crank position sensor so I told him I would change it. I get everything apart and like a dumb ass I put a ratchet on the timing belt tensioner pulley to get to the sensor well doing this screwed up the auto tensioner. So I started to turn over the engine slow as per a tech manual and it jumped time now I have the #1 at what I believe to be TDC.
Here is a pic of the drivers side which both cam gears are lined up with the marks that are on the valve cover. Yellow dots are timing marks.
This is the passenger's side both marks are off..Yellow dots are the timing marks.
The timing mark is lined up on the crank also. The idler pulley for the cam tensioner is off also what started off as a simple job has turned into a nightmare. If anybody lives out in Yelm and can give me a hand I will make it worth your time with cash I need to have this done in the next few days. I am just a bit parnoid messing with timing a lot can go wrong.
