RH DESIGNS - NEW BILLET ROCKWELL STEERING ARMS
These arms are constructed from 1.5" 4140 steel. Completely machined for precision and accuracy. They are designed to bolt straight to stock rockwell knuckles. Also these arms are double shear while utilizing the stock knuckle tie rod location for added strength. This new design is also double pinned in the mounting bolt area with (2) 3/8" dowel pins that are drilled into the knuckle for extra support.
Arms are sold as a axle kit that includes:
- (2) Billet Arms RH &LH
- (8)Grade 8 Mounting Bolts & Washers
- (2) Grease Fittings
- (2) 3/4" Grade 8 Bolts & Nuts for Double Shear
- (4) Stainless Misalignment Spacers
- (4) 3/8" Dowel Pins
- (2) Stainless Tapered Spacers
- (1) Drill Bit for Dowels
"RAW Steel Finish" No coating supplied
$550.00 per kit
Call or email if you have any questions
423-614-6277 ask for Riley
[email protected]
$550.00 per kit
[email protected]
