Sold/Expired New...CNC Formed Control Arm Brackets!!
Ken_00
Tulsa, Ok
These control arm brackets are something we've had in the works for quite some time.
Now here they are materialized!!!
Available to order directly off our website....www.KORE4x4Customs.com
Lower Control Arm Mounts for the frame side - $25.95
- Mounting width is 2 5/8". Perfect for most aftermarket suspension joints.
- CNC cut from 1/4" plate & formed on a press brake for precise fitment.
- Integrated lower gusset makes for an very strong bracket.
- Brackets are fully welded in a jig to keep distortion down to a minimum.
- Available for left & right sides
Universal Upper Control Arm Brackets - $14.95
- These are cut from 3/16" plate & formed on a press brake
- Mounting width is 2 5/8" wide
- Bolt Hole Size is 9/16" and can be drilled to desired size
- Designed to be used on top of a truss or attached to the frame for upper control arm mounts
Axle End Upper Control Arm Bracket - $24.95
- Cut from 3/16" plate & formed on a press brake
- Designed to fit on any 3" radius axle, but can be easily enlarged for bigger diameter axle tubes.
- Optional gussets are available
Ken, I need two of the lower mounts. Any change you can make them without the fish plate on top? I am not sure that will work with my setup. Great price and beefy product.
Thanks for the props Matt....ever wonder where all the centers from our beadlocks went to? ;)
At this time we don't have any lower mounts without the upper plate on them. Depending on exactly where you're going to put these, they could be modified a little to fit I'm sure.
The next brackets coming up will be lower control arm mounts for the axle and then the plates like Matt described.
Have a great 4th & be safe!
-Kenneth
Got your order processed & boxed up....UPS should be here any minute.
Thanks for the order Matt. Post up pics of the install.
TTT!
Bump for ya Ken, man these brackets are nice. Thick, huge gusset and nice welds. I was amazed at the sheer size of them when I opened the box! Nice product
Thanks again Matt.....Now where are the installed pics???
Stay tuned guys, our Formed Lower Control Arm Brackets for the Axle end are coming soon!!
I am rolling over to P's in a few weekends to put those on and to add some reinforcement to my cage. Looking fwd to getting them on!
Here's the newest addition to our 4 link bracket line....
3" Dia. Lower Control Arm Mount - 0 Degree Offset 1/4" Thick
- Same 2-5/8" wide mounting width
- 9/16" Bolt Hole
3" Dia. Lower Control Arm Mount - 10 Degree Offset 1/4" Thick
We also added these to our lineup....
Curved 3" Dia. Shock Mount 1/4" Thick!
