NITRO Ring & Pinion GIVE AWAY!!!!!!!
saturday
This is what happens to an ARB when the pinion nut loosens and allows the pinion gear to walk into the ARB housing. Thank goodness ARB is local and parts are available....
Signed up! :awesomework:
As an Amazon Associate we earn from qualifying purchases. Product prices and availability are accurate as of the date/time indicated and are subject to change.
Sign me up!
:D
bent the housing bad enough and axles that it had to be cut apart to get the bobby long birf's out of it!
D60 gears out of my daily driver.....they dont like 41'' irock's
toyota 5:29's pinion....and 39'' boggers =)
toyota rear axle twisted off in the 3rd member!
pulled the front drive line apart then it rammed into the ground stoping the truck and snaping it....gay
To compete in this give away all you have to do is submit YOUR best DRIVETRAIN CARNAGE PHOTOS!!! Let your WORST luck become your BEST!!!! Also, include the story behind it.
RULES: Its simple....they need to be your pictures, nothing you found off the internet.
signed up
sign me up boss:awesomework:
Sighn me up pls:corn:
read much?:corn:
The only breakage I have ever had is when I was taking off from a stop sign in my old 69 bronco and the slip yoke blew up, found it 20 feet from the rig, but no pics... It was late. In for 5.29 V6 toyota.
EJS 2007, Potato Salad Hill, Got all the way to the top, the double ledge at the top was killin me, I was workin it back an forth, back an forth when I decided to "bump" it allitle. Eugene hopped , all four in the air, I didnt get off the skinny pedle fast enuff and " BANG" the nose cone on my 9" blew apart. Took out the R&P, nose cone , the whole 3rd member. Randy's R&P was way cool, they repaced the R&P and sold me an experimental (Thick an Beefy) 3rd member. I was back up and wheelin in less then 24 hrs. :awesomework:
i have nothing on pic , it sucks but im mostly wheell a yota so my junk stays together ...
but heres some carnage , hunting two years ago and my rifle blew , , i think i shat my pants and couldnt hear for a week ...
I'm in for a set of dana 60 5.13's.
story is I was hammering at the water fall in Browns camp. When I blew a front shaft wich took the detroit with it.
dana 60 u-joint carnage
35 spline inner shaft
detroit
I have a new breakage from this weekend if I can enter twice.. Blew up my CV driveshaft
    36.2 KB
Pics are for guys that dont wheel hard enough and have to much time if they are taking pics...:eeek:
Okay, I am making my decision tonight! I will let you guys know first thing in the morning! If anyone else wants to get added, now is the time to do it. FINAL CALL!
Thanks,
Jeff:beer:
