No loss air chuck to fill shocks?
not local, but aircraft supply has one that i use that works like that.
you could make your own manifold with a shut off valve.
I just bought the one off polyperformance.
http://www.polyperformance.com/shop/Synergy-Suspension-Nitrogen-Fill-Adapter-With-Hose-p-28965.html
Description:
Affordable easy to use nitrogen fill adapter for filling shock absorbers
Assembly contains a special no loss air chuck valve so no pressure is lost during filling
Features a built in pressure gauge that allows the shock to be filled within 1 LB. of accuracy
The braided high pressure air line allows the gauge assembly snake around chassis components to easily access the shock shrader valve.
Critical for air shock applications
Hose length = 22"
i just set the regulator and plug it in .....:wtf: 200 psi. if i for any reason decide to check them i lose 2 psi? or just plug the regulator in again...
am i missing something here? the shock cant tell the difference between 200 psi and 198 psi......:D
