Not my Carb
Ms. Pink
Eatonville
So took my jeep down to the carb shop to check the floats once again. Nothing wrong. with the carb Ive got 7 psi from the pump but hardly any flow. No leaks in my hard line an no kinks or leaks in my rubber. Clog in the tank? Run the manual an electic pump at the same time still the same issue. Hardly an fuel pushing through the lines but good pressure. Im confused.:booo:
Where are you checking the pressure? You probably have a plugged filter or screen. What kind of carb? How do you know you have "hardly any flow"? Does it have running issues?
You can have pressure without much flow.
Most tanks have a sock type screen on the pickup that could be pluged up, or a filter some where.
