Sold/Expired NV3550 5speed/208 complete swap Ford sb or Chevy sb
frittsx4
Here is everything to put nv3550 5speed behind a small block ford.
NV3550 Trans w/shifter
Ford butterfly bellhousing w/adapter
32oz Flywheel 351w will need 50oz flywheel if using later 302
11" clutch disc & pressure plate
Clutch pedal for jeep yj
Master & slave cylinder w/mounts
208 transfer (w/new chain)
Pilot bushing
This is a good set up for putting a small block ford in a Jeep CJ, YJ, TJ, or what ever you pick. This can also be used with small block Chevy but new bell housing must be bought. This works well with any thing under 350hp I'm going pass that and didn't won't to junk this setup.
For all the parts I'm wanting $600.00
Just for parts that are needed to do the Chevy swap $350
Call David at 270 nine 65 zero zero 79
Marion Ky.
Some small block ford parts, automatic transmission/ transfer cases we can do some trading :dblthumb:
Yes sir this one had a 231 on it before and it has a jeep 208 on it now
Sept 20th '13: Still have these parts for sale? Would like all but the transfer case. Have an NP231 now.
Thanks.
Trans and transfer is all that's only things still for sale $250.00 firm
