power door wireing help
toyota4x4matt
Graham/ elbe
how do i wire up a set of power doors to a nonpower door truck? i want power doors and i have a set i would like to make work. so would i need to get power from my ing and a ground and some relays and find power in and out of the window moter?? not sure, looking for some HELP... this is on an 85 toyrunner.
If your not fluent on electronics I would have somebody who is knowledgable help you matt. Since your going to need to use a series of relays its a tricky setup to do....
The power window regulators are a direct swap with the manual ones you have already so there's no issue there. Your best bet is to get the whoel shebang from a wrecking yard and swap it out with yours. There is a short wiring harness that pulgs into the motor and switch then runs into the side of the firewall. You'll need that harness as the rest of the harness that connects them together is under the dash already so ther eisnt any wiring involved.. just install everything and put the factory relay into its spot int he driver side kick panel fuse box...
What he said.
Thanks WHITE TRASH. I guess iam off to thw wrecking yard tommarow. or dose anyone have this? anyway thanks for the help guys. keep it coming.
I might have the short harness's hanging around if ya can't find them. I know I gave the window regulators away but I do have the door panels still in decent shape.. dirty but not thrashed last I saw...
