Pre pump filter?
leeman1790
Alabama
I'm wondering what y'all are running as far as a before the pump filter. I want something that pretty much strains the fuel before the pump to keep larger stuff (foam,dirt,lizards) from killing the pump. I have an AC Delco filter after the pump and my whole fuel system uses -6 AN fittings so I want to keep that. Running the same filter before and after would be simple, but I'd like to be able to take the before filter apart on the trail and clean/replace the element if need be.
What's a good micron size? Anyone used something like this
http://www.summitracing.com/parts/RUS-650133/
The bigger lizzards never get out of the tank, so another fuel filter will not help. Mine had a head larger than the 3/8" line. booyang
Went with this. Works perfect with the hose coming from the tank then making a 90* turn into the pump and to the engine.
