Sold/Expired Project Part out!! **PRICE DROPS**
JFab
Huntsville, AL
narrowed tj body has been narrowed to about 44" between the doors. 2 22" wide seats will fit side by side while touching each other. includes tub, cowl, half doors, grill and hood. will need to be finished out. $500
front chevy d60, complete, but needs to be reassembled. knuckles have been bead blasted and painted, 4.56 gears with welded spiders. the axle tubes have been sleeved to beef them up. $800
5.13 d60 standard rotoation gears used. $50
trail gear creeper joints, 4l and 4r, 1.25" stud with 9/16bolt hole. new. comes with spacers, jam nuts, and threaded inserts. $400
ford c4 to dana 300 adapter. works for 2wd and 4wd transmissions. new in box $475
7/8 heim joints with 3/4 hole. qa1, new. 3l and 1r. comes with high misalignment spacers and jam nuts. $175
walker evans 14" air shocks, 2" diameter bodies. includes seal kit and a spare body. $300
ford 302 headeder flanges new $125
ford 302 moroso oil pan. deep sump oil pan with baffle, pick up and dip stick. new $230
custom btf high steer arms. these were built for the red bull racer so they are a shorter legnth than the off the shelf arms and on arm is double sided. these are to put the tie rod behind the front axle, but can be used in several different ways. includes studs kits. made for heims. measures 5.5" from center of kingpin to center of bolt hole. new. $200
psc p pump. new. for use with an external reservior. $100
http://www.pscmotorsports.com/motorsport-specific-products/offroad/steering-pumps/80-newer-hi-performance-p-series-pump-with-remote-can-6-an.html
fox 14" air shocks, 1 needs new lower mount, both need to be rebuilt. $100
Call or text James at 256.652.3029
Will ship at buyers expense...
James
Re: Project Part out!!
Send some of the fox air shocks that need rebuilding.
Thanks patrick 205 337 8037
Sorry for the delay, guys!
There are two walker shocks in like new conditio..
Ill take pics of everything tonight!
Thanks,
James
