If you are going from the tank to the block off you have choices. You can pay out the nose threw Nash (DICKHEADS) or you can just go to your local Fluid Power Supplier and get the hose and fittings at half the cost. It is specific stuff you can get at any length you want. I would suggest you get the fittings and extra hose to fix it on the trail if you cut a hose.
