Sold/Expired Propane Systems, Parts and Tech Help
altfuel1991
Precision Sales & Service, Inc.
451 64th Place South
Birmingham, Ala. 35212
877-403-7827
www.alternatefuel.com
[email protected]
We have been in the propane and natural gas conversion business for twenty years.
Propane systems for engines up to and over 900 horsepower. Systems built to match your engine no matter what size.
[attachment deleted by admin]
Great products and great Guy to deal with. Ran a dual Propane setup on my big block, made it come to life.
Would you please give me a price on a model E evaporator, a lock off and a rebuild for a imp co 425 to 37840
See my earlier post. The air valve assembly cost $61.00. Most of the time a diaphragm is all that is needed. Be sure to check the housing for wear, it is critical.
Buddy
buddy has all ways done a great job on my buggys
I have a post missing.
Impco Model E vaporizer $220.00
Impco VFF30 lockoff $61.00
Well, I am not sure what happened to a reply I posted earlier today.
The 425 mixer does not have a rebuild kit . The air valve assembly is available as well as the idle diaphragm.
Before buying any parts check the amount of side play the air valve has when fully seated in the housing. If you can see the air valve move then there is too much wear which will cause hard starting and a rough idle that cannot be adjusted out. The air valve runs with about .002" clearance.
Normally all you will need is an air valve diaphragm and possibly an idle diaphragm.
Both diaphragms together run about $30.00.
Buddy
877-403-7827
Bubba,
I will get back with you the first of the week. I am sitting at home recovering from a hernia operation right now and I could not get everything done before going in for surgery.
I apologize for the delay getting the info to you.
Buddy
If you need Propane call Buddy! He knows his stuff! From single set ups to dual setups, Buddy can hook you up!
