patooyee
- Joined
- Sep 27, 2008
- Messages
- 5,692
I have a really nice chuck that came with my lathe but it didn't come with a back plate. My lathe nose taper is L1. So I bought a semi-finished back plate and turned it down to size. But I screwed up on the last cut and went a few thou too deep causing the back plate to be just a few thou too small for the bore on the back of the chuck. Mad as hell at myself for doing it on a $200 back plate. I'm trying to figure out a suitable way to salvage it. Some ideas I've thought of are to get some shim stock and wrap it around the OD to take up the few thou in slack or to weld around the entire back plate dia. to add material and then re-machine it. The back plate is cast iron though and I'm not sure what an appropriate welding process would be or if I can easily cut on a weld. (I can TIG or MIG if needed though.)
Short of trashing the back plate what would a real machinist do?
