sastaco
New Member
i just put a t100 rear sump oil pan on my tacoma to claer hy-steer and i cant seem to find the spot for the t100 dip stick and dipstick tube. any pointers would be appreciated. thanks, Ryan
you did change the pickup too?
on the side of the block on the driver side is a flat spot kinda angled in. Some are drilled and have a dummy bung pressed in, others are not drilled.
If not drilled, I prefer to plate the side of the pan and weld the dipstick reciever tube to the pan and support it with a few gussets at the pan and a bracket close to the opening at the top.........kinda like a chevy VAN oil pan. Then I just cut the stock one and slide it back in to plug the stock tube up front.
I did Odies red truck this way years ago. :awesomework:
Just dont go to jiffylube, the techs will wonder why it has two dipsticks!!!:beer:
Mines a 96 too...pretty simple stuff but the plug was kinda a ***** to locate. Sorry I forgot to snap a picits a 96. maybe i will pull the pan back off and use a punch like you did.![]()
