JDodd
I am getting a I set of these cut and wanted to see if there is anyone else interested while I am ordering them. The complete set is $1,500 and comes with body mounts, suspension mounts, and the pre cut frame material. I can also supply additional parts need as in:
Plate style shock towers
Bump stop mounts
Plate bumpers
Skid Plates
Coil Over and Spring combo for the right ride height
Aluminum links designed for this set up
A little back ground behind this, I have built several jeeps and honestly the only way you can get decent up travel with a low ride hight is to cut the font and rear portions of the frame and move them up closer to the body. This only leaves a 4' section of the original frame so I decided to design this to save time, instead of cutting, grinding and rebuilding the factory frame you can start with a clean slate and stronger then just adding on to the factory one.
Justin Dodd
(615) 308-9372
[email protected]
All the brackets will be cut as seen here so they can be hand bent to the correct angles and welded
Bump stop mounts
Plate bumpers
Skid Plates
Justin Dodd
(615) 308-9372
[email protected]
