J.A.B
- Joined
- May 29, 2008
- Messages
- 2,177
Originally a WOD Revolution chassis but now has the WOD Evolution front end on it. I bought the buggy from Tom in Feb of this year. In April / May of this year WOD made a bunch of changes to the buggy.
Basic Specs..
6.0 lq 4 / Cam and spring swap with a Lane Culiver Tune. The motor makes good power and sounds good.
Ford HP Dana 60 front / 5.13 gears / Yukon chrome moly shafts / Super joints. / Detroit
New Atlas 3.0 with 1350 / 1450 outputs. One ride on this case.
Built TH 350. Has manual valve body but NOT reverse valve body
14 bolt rear / 5.13 gears / Spool / WOD truss and pinion tie in and has been re-tubed. One ride on this axle
43 SX Sticky and Raceline beadlocks with no rids at all on them
All AN fittings and braided hoses.
UHMW skids
The changes WOD made..
Replace the revolution front end with evolution
Redo steering - pump / lines / relocate
Add alternator relocation kit
Install 14 bolt and related drive shaft work
New 7075 links on the rear
All sorts of other odd and end items that add up. The work WOD did on the buggy totaled right at $15,000, I have the receipts if anyone wants to see them
I can supply pictures of anything else. There are many other nice components to the buggy. I have put a lot of money into this buggy since buying it and had a lot of stuff redone since . It functions and rides good and just plain works.
Few items that are an issue now and will be 100% addressed before a sale.
- Leaking rear axle seal
- Small water leak on the thermostat housing gasket
- It has a plastic fuel cell in it now ( just to keep it usable until a new one is built ) but I am in the process of getting a new aluminum one built to specs and will be sold with it.
- There are some scuffed places in the powder coat and the clear coat is coming of in places as well
- If someone desires to have the skins painted I will consider having that that done at my expense before selling if it fits the deal.
Located in Florence AL. 256-762-8877
$50,000 obo / I would consider partial trades on a nicely built streetable TJ
Basic Specs..
UHMW skids
