Sold/Expired Rockwells, Tons of extra parts, bead locks etc.
YOUNG
South Florida
Everything is located in Clarksville, TN. 40 miles North of Nashville. Call Bryan at 931-648-7086 or 931-237-7464 if interested.
All of the parts are for a 2.5 ton Rockwell
1 stock take-out rear axle complete
1 rear axle complete (minus third member) with the bottom cut/shaved, factory drum brake flange cut off smooth
1 front axle complete with the bottom cut/shaved, studs removed, 3/8" grade 8 bolts installed, hubs flipped and cut for weight savings (5 lbs. each). Spindle studs hae also been removed and replaced with bolts.
4 extra stock rear shafts
4 extra front spindles
2 extra front drive flanges
2 extra front side long shafts with joints and stubs
2 extra stubs with joints
Pinion mounted brake brackets for THREE axles
2 bottom plates for the shaved housings
32 bolt Ballistic Fab DIY beadlock kits
4 Rockwell wheel centers
4 15x10 steel wheels with the centers removed and smoothed out
2 stock take out drive shafts
Other various side and top plates for third members.
$2000 obo for the package
